Question about 'Break in Oil'
RE: Question about 'Break in Oil'
Ford does use a synthetic blend as a break in oil, designed specificly to coat your internals before you go synthetic. Somewhere between 500 and 1000 miles, switch to a FULLY synthetic of your choice. (I use Mobil 1)
Just read Owners Manual ( this was bothering me .. lol ) it says under " normal driving" every 5,000 miles.. but as vicmeldrew pointed out .. the three month thing is a bunch of Bull Shliltz.. I have seen cars on the lot for over a year without a oil change .. do you think they sold that car and the first thing they did was bring it in and change the oil..?? I don't think so.. plus how long do you think the car sits at the plant before the dealer gets it..?? just some thoughts...
Rex
Rex
ORIGINAL: JT_Moore05
Ive got a 06GT and I just hit the 3000 mile mark. Ive heard stuff about letting your break in oil stay in longer?
www.bobistheoilguy.com
I changed mine at 3000mi with a FL-820S and Motorcraft 5W-20--both of which I got at Walmart.
Mike
Is full synthetic really that beneficial for the engine? Is there any proof that the synthetic oil is better for the engine? I've always used Quaker State 5W-20 and have never had any problems. Everyone says that I should go to full synthetic, but why?
ORIGINAL: Newbreedgt05
As stated before, go to "BOBISTHEOILGUY" website. More oil info than you could ever digest.
To answer your question, the popular concensus would be that synthetics are a better oil IF you do extended drains and race the car. You will get, although, many opinions. But what is an extended drain for a particular motor - 3K, 5K, 10K 15K?? For a 5K drain interval, I believe if you use the Ford Oil (5W20), labelled as a "Synthetic Blend" (which is BS), you will have all the protection you need. If you race it, want to change the oil at longer intervals, maybe want alittle cleaner motor, then the higher cost of a REAL synthetic oil (Amsoil, Mobil, Redline) may make sense.
The 4.6 Ford motor is a very "mild" motor in terms of HP output and compression. It was designed and built that way to ensure a long motor life with average build materials and metallurgy, and to make it cheap to build. There is really nothing special about this motor - it could be happy in a police car or a truck with a different cam. If Ford wanted to (eg the market demanded it), for less than $500 bucks, the 4.6 V8 could put out easily 400 HP stock with just better materials and parts, better compression and a better cam. A 4-valve head with double overhead cams would also benefit this motor beyond belief.
The oil change is so simple that there is no reason not to do it yourself. Buy an oil pan that you can take your used oil for recycle. Cost is about $6. If you don't have a spot to do it yourself even the Jiffy-lube places sell and install Mobil 1 and the like. Just keep an eye on them. It is a very simple procedure. I'm living proof
I always change the oil myself cause I like to fill up the filter with oil too, so the engine has oil from the instant it starts. I don't think the oil change places do that and I don't trust them anyways. I'll think about changing to synthetic oil though if it might be a little easier on the engine. I don't mind the extra cost.
