Sponsored by:
Sponsored by:
Flat spotted tires?
Old 04-07-2006, 10:01 PM
StartMeUp
StartMeUp's Avatar
Default Flat spotted tires?
Hey guys. When my 06 GT sits for a while (overnight) the first mile I put on it the ride is bumpy feeling. Almost like the tires developed flat spots. Once I get up to speed it quickly goes away. Has anybody else experinced this? Keep in mind that I live in PA and have only had the car since January so it hasn't seen much warm weather yet.
StartMeUp is offline
Old 04-07-2006, 10:17 PM
Tik_Tok
Tik_Tok's Avatar
Default RE: Flat spotted tires?
My car sat for 5 months. I had flat spots, but they worked their way out in less than 10 miles. have never experienced it overnight.
Tik_Tok is offline
Old 04-07-2006, 11:09 PM
StartMeUp
StartMeUp's Avatar
I should mention, the car has 17" wheels with the stock Pirelli tires.
Old 04-07-2006, 11:10 PM
blackfoot
blackfoot's Avatar
cehck your tire pressure
blackfoot is offline
Old 04-08-2006, 03:19 AM
Cobrakev
Cobrakev's Avatar
How low are you running your tire pressures? It may take a few miles for the tires to heat up and raise the tire pressure. It is a common problem on low profile tires when tire pressue is set on the low side.
Kev
Cobrakev is offline
Old 04-08-2006, 12:40 PM
BeeStang
BeeStang's Avatar
If it doesn't go away, you might want to check the balance. There is a possibility that you have a bad belt in the tire. This has happened to me. It's from hard driving and sometimes just a defective tire. If this is the case, the tire would be replaced under warranty at a tire dealer that sells Pirellis. You have the warranty info in your folder with the manual.
BeeStang is offline
Old 04-08-2006, 05:29 PM
Redfire
Redfire's Avatar
Ive noticed this with my '05. I use it on the weekends, and its about a mile from my house to the highway. I notice the "thumps" for a little bit when getting up to road speed. Its the dam Pirellis.[:@]
Redfire is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
69Volunteer
09-30-2015 10:39 AM
popsotto
09-28-2015 06:58 AM
Quick Reply: Flat spotted tires?
