help with scratches on headligh cover,s
ok last summer i had a hell of a time getting dead bugs off the head light covers.[:@] i tried everything but still some remained so i try one last thing 000 grit steal wool the stuff you use between coats of varnishing. i did it really light and it worked until night with the head lights on i saw a haze at closer look i saw the fine swirl like scratches..so after calling my self every name in the book i look around to see if their was something out their that will remove them with no luck..dose anyone no how if anything can be done besides replacing them..
RE: help with scratches on headligh cover,s
Meguiar's has a plastic cleaner/polish. "PLASTX" which I've used with some success on motorcycle helmet shields.
I'v heard rumors that some bugs is some states are really tough critters. Here in the SF Bay Area I clean off my front end almost every drive, using Meguiar's "Quick Detailer" and/or there Nxt Generation Quick Detailer. Both work for me!
Yup, there are lots of plastic/acrylic polishes out there. Gonna need some elbow grease too. An electric buffer would help as well. For future reference, never use to clean, anything harder than that which you are cleaning. (i.e. never use metal to clean plastic.) Just use the Turtle Wax Bug and Tar Remover. Spray it on just before you wash the car, then while washing the rest of the car, use a wash mit to rub those guts right off. If not doing a full wash, the Bug and Tar can be used like a detailer as well. Works great!
Folks like Clearmask that sell clear 3M bras also sell just head light protector kits, they are pretty easy to install since they are small pieces. If you can get your lights cleaned back to where you like them, you might consider a protector like this. I have been happy with mine. I also apply Rejex on top of the 3M material to make cleaning very easy. It works.
When I used to use the Turtle Wax Bug and Tar remover, I used to have a problem on my old car. It would leave a waxy like residue that I couldn't get off that would allow dirt to stick to it abnormally easy. One drive down the road and you could see exactly where I applied it. Maybe it was just me though.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
