Sponsored by:
Sponsored by:
What's the wattage of shaker 500 8" Subs?
Old 05-05-2006, 08:13 PM
  #21
Sleeper05
Sleeper05's Avatar
Default RE: What's the wattage of shaker 500 8" Subs?
ORIGINAL: JJ_Stang
The existing amps are TWO channel? I assume one channel for the components and one for subs in each door?
Nope the amps are only for the subs the Component speakers in the door are powered by the head Unit. 1 Amp per Sub, 1 chgannel per Voice Coil. The Amps are both located in the upper left hand side of the drivers foot well they are 2 small silver boxes.
Hope that helps.
the existing amplified head unit is 4 channel, and the shaker system is 5 channel. the channels consist of FL, FR, RL, RR, and sub. this is how you are able to to fade (front to back) and also balance (side to side), with seperate sub adjustment. however, only one channel controls both voice coils of the subs, which are wired together in series most likely
Sleeper05 is offline
Old 05-05-2006, 09:21 PM
  #22
Skrappy
Skrappy's Avatar
Thes subs are DVC with a channel from the amp to each one. The amp is fed the exact same signal to each channel, so that the speakers see the same thing from both channels at the same time. So the sub is fed two signals from the same amp that are identical.
Sk
Skrappy is offline
Old 05-06-2006, 03:38 PM
  #23
skm52670
skm52670's Avatar
ORIGINAL: Skrappy
Sk
I think I get it now. The amps are receiving the 'sub' signal on input side. The amp then splits the signal to the two channels, since its the same signal on both channels, you can wire one channel to each voice coil? Right?
So each channel of the amp is 'seeing' 1.2ohms? Which means the amp would have to be stable at 1 ohm, correct?
I think I'm gonna get a book on this subject. I'm learning alot on this forum though...thanks for the info everyone.
Steve
skm52670 is offline
Old 05-08-2006, 12:54 PM
  #24
Skrappy
Skrappy's Avatar
You are correct!
Skrappy is offline
Old 05-08-2006, 06:56 PM
  #25
skm52670
skm52670's Avatar
ORIGINAL: Skrappy
You are correct!
[sm=happy046.gif] Do I get a 'star'?
Seriously though, thanks for the help
Steve
skm52670 is offline
Sixer4Life
09-29-2015 07:03 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: What's the wattage of shaker 500 8" Subs?
