Sponsored by:
Sponsored by:
Short Throw Shifters...Which do u like?
Old 05-08-2006, 01:23 AM
SweetGT
SweetGT's Avatar
Default RE: Short Throw Shifters...Which do u like?
ORIGINAL: mac10chap
i was gonna go with the Hurst or Steeda also but my shop guy told me that he has been installing that little adapter from steeda and a set of polyurathane bushings into the stock shifter and it is just as good as the whole aftermarket assembly and will save you a couple hundred dollars
Well then, know where to get that adapter and bushings for cheap. I am all about not spending money if i dont have too, haha.
SweetGT is offline
Stewart
Stewart's Avatar
Anyone have a link for that adapter?
Stewart is offline
Old 05-08-2006, 09:26 AM
QuickShortBus
I ♥ Acer
QuickShortBus's Avatar
The adapter is from Saleen look around on their website, I don't have time right now. The poly bushings are available from Steeda.
The problem most people have shifting into 3rd in these cars is because the motor is torquing over against the stock hydrobushings. If you use torque limiters or good motor mounts 90% of the shifting problems will be cured and also help transmit power to the ground more efficiently.
The Hurst with the chrome handle is more or less a stock shifter with a shorter throw it isn't any stronger it just looks pretty.
B&M uses some parts from the stock shifter (not the best idea IMO). it also has a design flaw that was causing a bolt to come loose and fall out leaving cars stranded. B&M's fix was telling customers to use locktite on the bolt. I know of 2 individuals that have now had that bolt break and now that part that the bolt broke off in was part of the originial shifter so they are stuck trying to find a stock shifter or buying one from Ford for $200, oh and B&M isn't being of any help.
QuickShortBus is offline
Old 05-08-2006, 09:52 AM
gregt909
gregt909's Avatar
Here's the saleen link. This thing used to be about $25 or so. Looks like they raised it to $50.
http://www.saleen.com/SC101_Services...0-2705-B11516*
gregt909 is offline
Old 05-08-2006, 11:19 PM
Stewart
Stewart's Avatar
How much did the kit and bearings cost for the installation?
Stewart is offline
Old 05-09-2006, 12:11 AM
Lone_Star_Stang
Lone_Star_Stang's Avatar
I only used the block, feels absolutely great for me. I got it when it was 25, at 50 bucks it's still a bargain.
Lone_Star_Stang is offline
Old 05-09-2006, 12:17 AM
Fly
Fly's Avatar
ORIGINAL: 1QuickShortBus
I love my Hurst, but it has this same problem. First time I reinstalled them with a little loctite, second time I used a bunch of loctite (red) and torqued the snot out of them. If they loosen up again I'm going to try through bolts with jam nuts on the other side I guess.
Fly is offline
Old 05-10-2006, 10:28 PM
Vcoat
Vcoat's Avatar
I just had a hurst installed and so far i love it !...Its a nite and day difference over stock..very notchy but i like that..I dont hear any vibration at high rpm's. I can see where power shifting might be a problem but i dont do a lot of power shifting if any so far.
06 GT, White, 5sp, 3.73's, Hurst, Lots of MGW Chrome...C&L and tuner from Brenspeed coming this Friday
Vcoat is offline
Old 05-10-2006, 10:30 PM
typhoon007
typhoon007's Avatar
Count another vote for the hurst... Gotta have the white ball too! That's what really makes the difference. [8D]
typhoon007 is offline
mrtrodonet
09-19-2020 03:12 PM
jrrhd73must
10-02-2015 09:17 PM
Drastang
09-30-2015 03:48 AM
mustangheaven
09-29-2015 11:00 AM
junior04
09-28-2015 10:53 AM
Quick Reply: Short Throw Shifters...Which do u like?
