Just installed 93 oct base tune, car need to re-learn?
RE: Just installed 93 oct base tune, car need to re-learn?
ORIGINAL: StevesGT
Its an XCal 2, with a basic off the shelf SCT Tune. No CAI, and its a stick.
ORIGINAL: drbobvs
Where did you get this tune? Is it w/ a Predator or SCT? Are you Auto or manual? Do you have a CAI?
These may be important
[IMG]local://upfiles/16153/3932A8B04A4B4F6C95B07069D214BF0A.jpg[/IMG]
i felt mine big time, then again i went from stock, to pullys C&L Intake with 93 tune and cat back exhaust with a custom x-pipe all at the same time
So if running a 93 oct tune doesnt gain much in hp results, I might as well save some money for now and deal with the 87 oct tune? I mean if I am really only getting a couple hp using the 93 tune over the 87, whats the point for now?
ORIGINAL: StevesGT
Put 4.10's in the rear end ( best bang for the buck IMO ) then post again... also a C&L CAI won't hurt.
very easy to install....
best mod I did was the gears.. I went with 3.73's .. but your car came stock with 3.55's so if you go to 3.73's you won't notice much.. mine came with 3.31.. I get better mpg after the gear change..
so if I where you I would put in 4.10's .. you are in a higher gear ( when shifting) before you know it..
why I think I get better mpg... you have to get moving first... then it is not hard for the car to keep you going...
EDIT: you will need a dyno tune also.. that way everything is just right...
JMO
Rex
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
'stangdude
08-12-2015 01:27 PM
