? for those with Saleen HID's
Hey everybody. I recently installed a sdet of Saleen HID's and have noticed a couple of issues. I want to know if anybody else who has these installed has the same issues.
1st problem has to do with the passenger side. While the lights are on, it seems to shake a little bit when hittting bumps or simply shutting the door. It is annoying. I had someone shut the door while observing and noticed that it is not the housing or the bulb itself. Rather, it is the little motorized shield that sits over the bulb that is the cause. I think the little cover is the thing that moves to change from high to low beams. If I turn the high beams on the shake in the light is gone.
2nd problem is that the housings seem to be allowing quite a bit of dust inside the housings. I have only hads them installed for about 4 days and there is what seems like alot of dust inside the housing already. I checked the back rubber boots and they are sealed very well. I took a look at hte original housings and there is NO dust in them at all.
I am asking these questions to determine if this is just normal stuff I should expect or should I request a new set? As those who have installed these things you know its quite a bit of work to put them in.
Thanks in advance.
Thanks in advance.
RE: ? for those with Saleen HID's
I have the Saleen HID set up as well. I haven't had the problems you describe. So far (1 month) everything has been fine. I would definitely talk to Saleen about you issues. Let us know what they say.
mungodrums
09-28-2015 10:54 PM
