MY HURST SHIFTER DIDNT COME WITH BOLTS
FIRST MY DIRECTIONS ARE DATED 12/05 IS THIS THE UPDATED VERSION ALSO IS SAYS TO USE THE SUPPLIED BOLTS AND STAR WASHERS TO CONNECT THE CHROME STICK TO THE SHIFTER BUT THERE ARE NONE IN THE BOX IS THIS NORMAL DO I USE THE BOLTS FROM THE STOCK SHIFTER OR DID THEY FORGET TO PUT THEM IN THE BOX THANKS 4 THE HELP
RE: MY HURST SHIFTER DIDNT COME WITH BOLTS
You should have got bolts and star washers. Call the vendor in which you bought it from and tell them to expedite those F%$#@%! pieces. I assume your pissed by all the caps.
Yep, you should have the bolts in the Hurst box. IIRC they are wadded up in a bubble wrap. Make sure you didnt accidently throw them out with the packing material. You cant miss them because they are black allen bolts and they are heavy.
junior04
09-28-2015 10:53 AM
