clear corner light install help, please
What is holding the inside of the corner lights? I have removed the covering plug, but I can not tell if it is a screw or what inside the "black tube".
Help, tips, appreciated. Thanks, Mike.
RE: clear corner light install help, please
mim3,
There's only screws in the wheel well cover where it's attached to the front bumper. There aren't any screws holding the lense in, just the two white tabs that you squeeze together (I used a pair of needle-nose pliers) to pop out the lense. The inside edge (closest to the grill) is tabbed and it fits in a slot in the bumper, so all you have to do is pop the white tabs loose and then pull the lense back and out to remove the inside tab from it's slot.
Takes about 5-10 minutes per side.
PM me if you have any questions....
UB10
UB10
Looks good MIM, but you still got the egg yolks in there! Need chrome bulbs! Here they are!
They are near invisible in the lens when off but light up a nice deep amber. Best addition to the clear lenses. I love the 18" polished bullitts
BTW!
BTW!
