Drag suspension setup
I am really wanting to be able to hook better and get my 60' times better. I heard that suspension can make or break you in the 1/4 mile.
So my question to you guys is what should I go with first? I will have to buy one part at a time due to me being low on money. (In college)
Thanks!!
Thanks!!
RE: Drag suspension setup
Lower control arms, and lower control arm relocation brackets would be the first thing I would do. You want the LCAs to control wheel hop, and you want the relocation brackets to help the weight transfer when the car accelerates. Those two things would be the cheapest things to start with. There are plenty of other things to look at, but personally I would ( and did ) start there. Next, would be drag shocks, and probably coil overs.
ORIGINAL: V8 Aggie
where can I find the control arms. Is the relocation kit a must if I upgrade or can I do that later also?
ORIGINAL: V8 Aggie
thanks man!
you plan on going to ennis anytime this summer?
thanks man!
Matt's 95 Stang
10-05-2015 07:16 AM
