Drive By Wire
RE: Drive By Wire
ORIGINAL: bl1nkage
sorry but... someone wanna explain wtf drive by wire is?
RE: Drive By Wire
Ooo I see... I noticed there was no way to manually rev the engine while under the hood. (I could do this on my old maxima) You could just push the little throttle thing with the cable attached to it.
RE: Drive By Wire
ORIGINAL: elektra
hmm, Interesting. So am I hurting my car with my driving techniques? I heard that it was okay but you go through brakes faster. Anyone else suggest David's veiwpoint?
RE: Drive By Wire
ORIGINAL: elektra
As far as mileage, the computer cuts off fuel flow when decelerating, and you're in a constant state deceleration going down hill, so you're probably not using much of any gas when in gear. On the other hand, if you're letting it idle, it has to pump enough fuel in to keep the engine turning.
RE: Drive By Wire
It's a poor practice.
If you have to make an evasive manuever, you should be ready to instantly accelerate.
Next, I'm still thinking the "neutral coasting" is messing with the computer. I don't believe the MT equipped vehicles have transmission sensors. Meaning "Spanish Oak" doesn't know what gear, if any, the transmission is in at any given time. So when the car is "coasting" "Spanish Oak is putting enough fuel into the engine to maintian the car's speed................... against a transmission that isn't in gear.
Braking bias may also be an issue. Although with ABS it's less of an issue. The brakes are "balanced" so that each gets a certain amount of braking force. Because of dynamic weight transfer, front brakes usually do appx 65% of the "stopping" Rears do appx 35%. The brake system should be balanced so that the fronts/rears are using the same percentage of the available traction. So one "axle" doesn't lock before the other. Part of that equation is engine power, supplied as if a AT transmission is in gear, or a MT transmission is in gear while the brakes are applied. Disrupting that balance will cause the brakes to be less effective at stopping the car.
RE: Drive By Wire
ORIGINAL: 2006RedGT
If there is no one around then there is no reason for this.
ORIGINAL: olym4gery
