Need help - Cervini's PIAA install
Has anyone done this install themselves? If so, can you tell me how you mounted the lights? The hole is so small that you can't get a screw in there to the bracket. -Joe
RE: Need help - Cervini's PIAA install
Oh well, I guess nobody else has done this or just not reading at the time. I couldn't wait and an idea came to me. It may not be the right way but it worked. So if anybody tries to do this and finds this post, this is what I did. I bought 4 screws and 4 lock nuts (the kind with the nylon at the tip of the threads). I slipped the lights into the sockets on the bumper, grapped the nut with a pair of needle nose vise grips and held the nut from under the car in the 6 o'clock position to the cup. Put the nut on the inside, towards the front of the car and push the screw in from the back. Works great and is very solid. I used the lock nuts so the fog lights won't come loose. -Joe
a couple Photos until I get a website built... Should be soon.
https://mustangforums.com/m_1312515/...tm.htm#1312515
09-10-2015 08:39 PM
