Sponsored by:
Sponsored by:
Removing etched in water spots
Old 07-06-2012, 06:13 AM
BlueBellThunder
BlueBellThunder's Avatar
Default Removing etched in water spots
Yesterday I gave my car a full detailing and when I was done I noticed some etched in water spots. I used to park it in the driveway and every morning it would get hit with the sprinklers. I've since been putting it in garage. When you look at it from about 5 feet away it looks fine but when you look up close at an angle you can see them. I've heard that either a clay bar or Bar Keepers Friend would remove them. I was wondering if the liquid version of Bar Keepers Friend would be safe on a cars paint. I've used it in the past for water spots on glass and it worked fine.
Thanks for all replys.
BlueBellThunder is offline
Old 07-06-2012, 06:20 AM
BigDinTexas
BigDinTexas's Avatar
Bar Keepers is an abrasive (however mild) and is really great for getting stuff off your windshield, but I would NOT recommend using it on your paint. You could try the clay bar, but your success might be limited.
Do you have a variable speed random orbital polisher like the Portercable 7424XP? I have the Griot's Garage 6" RO. I think you may need one of these and some polishing compound to get those water spots out.
Don
BigDinTexas is offline
Old 07-06-2012, 07:55 AM
09daytona
09daytona's Avatar
Sounds like you are gonna need to claybar. You could start with the mild and see how that goes. Meguiars makes an aggressive clay that you can use but then you are going to have to follow up with a swirl remover. Problem with sprinkler water is it usually contains high deposits and once the sun bakes away the water all those deposits are left to bond to the clearcoat.
09daytona is offline
Old 07-06-2012, 08:13 AM
moosestang
moosestang's Avatar
Try Meguiars cleaner wax. It removes everything.
moosestang is offline
Old 07-06-2012, 08:26 AM
stealth32
stealth32's Avatar
porter cable with meguiars 105 and 205 works wonders
stealth32 is offline
Old 07-06-2012, 08:32 AM
BlueBellThunder
What is porter cable. Thanks
Old 07-06-2012, 08:50 AM
siggyfreud
siggyfreud's Avatar
Don
Griots actually makes glass polish pads and compound for their 6 and 3 inch orbitals.
siggyfreud is offline
Old 07-06-2012, 09:39 AM
BigDinTexas
Yeah, I saw that recently... I've been itching to get them, but trying to justify the cost when I still have a whole container of the Bar Keepers Friend in the garage... LOL...
Don
Old 07-06-2012, 09:41 AM
05xrunner
05xrunner's Avatar
So far this is the only advise that will actually remove them..Clay wont do anything at all if its etched. you need to polish the paint with a machine and compound to remove the etching..clay will only remove dried on water spots where the mineral deposits are ontop of the paint. you still need to caly the car before polish anyway so it would be needed. Clay will not solve the problem though if they are etched water spots.
Cleaner wax again wont remove paint defects. it only removes paint oxidation and maybe some very fine swirls but it wont do anything for etching either.
05xrunner is offline
Old 07-06-2012, 10:17 AM
gothamems
gothamems's Avatar
^^^^100% AGREED^^^^
gothamems is offline
Quick Reply: Removing etched in water spots
