What size tires do I need?
I just purchased a set of 19 x 8.5 for the front and 19 x 9.5 in the back. I wanted to go with 275 in the back and 245 in the front, but I am not sure about the middle number. Do i keep the second the same for all 4 tires? I found 245/35/19 for the front but I am not sure what i should get the back, they have 275/35/19 and 275/30/19. By the way, I am looking at NT555's. Thanks and sorry I am sorta a noob with tires and rims.
RE: What size tires do I need?
For the front you can go with 235/45 or 245/45 if you want to get as close to stock height as possible. For the rear, if you want to keep your speedo calibrated, then you need 275/35.
Rule of thumb is for every 20mm in width/ reduce your aspect ratio by 5. Likewise, for every inch increase in rim diameter, also reduce your aspect ratio by 5. This is to keep the original tire height.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
M3hunter
09-05-2015 03:42 PM
09-01-2015 08:16 PM
