Hood Pin Location
#22
RE: Hood Pin Location
Does anyone have pics of the actual placement of the pins under the hood? I want to space mine out a bit more then the plates on the radiator support let you and was wonderign if anyone uses brackets or anything.
#24
That's the rad supports he's talking about.I did use the existing rad supports myself. Quick and easy! They work like a champ, my CF hood would rise/fall about 4 inches on a windy day. Pretty disconcerting. The hp's fixed that problem.
If I had to do over I'd put them further out but that requires drilling the front rad rail something I really didn't want to do...
#25
ORIGINAL: 05BlueGT
Here are a couple of pictures of mine.
#26
ORIGINAL: lmunz22
For those with the lanyards:
What did you do, if anything, to stop the lanyard from rubbing against the hood and destroying the paint?
I got the Shelby pins, they came with rubberized lanyards.
You can see the posts in this pic. Sorry, but the front end is sorta torn apart..
http://mustang.dnsalias.com/pics/lis...d=fwgidqorlpbn
#27
Check out my how-to in the the how-to thread. It has pictures and instructions...
https://mustangforums.com/m_3876208/...tm.htm#3876208
