Sponsored by:
Sponsored by:
SHOCKS AND SPRINGS
Old 07-24-2006, 02:13 AM
GT JIM
GT JIM's Avatar
Default SHOCKS AND SPRINGS
Need some help guys,
I am looking to put new shocks, struts and springs in. How hard is the install? What kind should I use? What about the panhard, I am not sure if I should also replace this?
Any help ????
Thanks,
Jim
GT JIM is offline
Old 07-24-2006, 10:01 AM
CrazyAl
CrazyAl's Avatar
Default RE: SHOCKS AND SPRINGS
All the spring brands perform about the same. I would choose the one you like based on how much drop it has. Also, stick with a well known brand like Steeda, Eibach, Roush, etc. Off-brand springs have been known to sag over the years, and you don't want that.]
As for the shocks, there's basically two choices in my mind. You can get the Ford Racing shocks which are pretty nice, and they're specifically tuned for our cars.
On the other hand, you can go with the Toikco D-spec shocks, which at the moment are the best around. They are fully adjustable for both rebound and compression damping, so you can set them however you like. An added bonus is that if you like to race (Drag or road) then you can always tweak them to "race setting" before you run, and then go back to a more conservative setting for the street.
The rear spring/shock install is very easy. Expect it to take an hour or less with hand tools, jack, and stands. The panhard bar is simple as well. You could probably do the rear shocks, springs, and panhard in 1 hr 30 min.
The front takes a bit longer and you'll need a spring compressor. If you don't have one, you can probably borrow (or rent) one from a local auto parts shop.
CrazyAl is offline
Old 07-24-2006, 11:48 AM
GT JIM
GT JIM's Avatar
CrazyAl-
Thanks a lot brother! I think the Toikco D-spec shocks sound great! I'm going to shop around an hopefully I have them installed this weekend!
Thanks again!
Jim
GT JIM is offline
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: SHOCKS AND SPRINGS
