How did you run speaker wires to your door?
RE: How did you run speaker wires to your door?
In the door jam, remove the rubber boot that goes over the plate. Once that has been removed, there is a gray plastic plate there with all the wiring for the door going through it. I though that was one side of a plug, but it is not. There is a plug on the "car" side of the hole that snaps in to that plate. But the plate itself is not a plug. It is merely a holder for the actual plug. So I popped the gray plate out of the hole, and with a small flat blade screwdriver I lifted the clips that hold the plug to the plate. Once they were separated, you can then stick your speaker wiring through the plate. The plug does not have to be snapped in to the back side of that plate. Looks like it is more for tension relief than anything else. And really doesn't do much for that either because the wires hold themselves up.
Anyway, by doing that you have room to run your wires. Just snap the plate back in to place and put the boot back on once you get the wiring through the rubber tube that goes to the door.
09-01-2015 08:16 PM
HorsePower99
08-26-2015 11:29 PM
