03-04 Cobra swap
RE: 03-04 Cobra swap
ORIGINAL: AntiHeightPunk
hey guys, i want a strong engine for F/I and since ive heard alot of bad things from the engine the gt has regarding boost i was wondering if a swap to the cobra motor has ever been done
Wait, youre wanting to swap out a 03-04 cobra motor with our motor? Why would you want to do that? The 03-04 cobras had iron blocks and were only rated for 8 psi.. theres people on this site running more boost than that in our aluminum one.. I would think it would just be better to SC our engine.. seems like youll get alot more HP out of ours than you will a cobra.
How much HP did HMS get out of theirs?
Dude, the block is forged, so is the crankshaft, connecting rods and pistons, that's going to hold boost a hell of a lot better than your aluminum block. Oh, and that 8 psi is stock boost, hardly what it can take once hooked up to proper levels of pressure.
ORIGINAL: NoOriginalNamesLeft
Dude, the block is forged, so is the crankshaft, connecting rods and pistons, that's going to hold boost a hell of a lot better than a your aluminum block.
i was gonna say, i thought my friend runs around at 17 PSI, but iwasent going to post that until i talked to him to make sure it was true, as said before i WILL do this swap if someone tells me if it would be possible. i mean i dont see why not but than again most know better than i do
Check the edit, it's only 8 boost stock. It's capable of oh so much more.
