Need help with aftermarket wheel fitment
I'm 90% sure these wheels will fit my 06 GT, just wanted to check here before pursuing.
Front 20X9 114.3 ET28
Rear 20X10.5 114.3 ET35
Appreciate anyone that could confirm or deny.
RE: Need help with aftermarket wheel fitment
you got the bolt patter right, but both the fronts and rears WILL stick out.
about a 20x9 with 35mm offset will sit fine up front, and a 20x10 with 35 will be fine out back....i tryed to fit a 19x10.5 with 35mm offset and it stuck out bad, buit if i brought it in with like 42mm offset im afraid it woul hit the rear shocks
Bummer
Thanks for your help. You saved me a lot of headache...
Is there a post here that lists what offsets fit on certain size rims? I searched but as usual, it didn't do me any good...
UMM i dunno, ill give you a good idea though. a 35 mm on a 9.5 tucks the rears pretty well, so im thinking a 38-42 on a 10" wide will work fine. on the fronts a 30mm offet ona 8" wide will be fine, and a 35mm on a 8.5" wheel....38-40mm on a 9".
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
