Stock Perelli Tire Pressure?
RE: Stock Perelli Tire Pressure?
ORIGINAL: LesteR723
i looked on the tire, the only pressure it had listed was max at 44psi.
and backinblack... like i stated earlier i got new wheels which are not only a differnt size but also manufacturer. I figured the pressure would be different. The reason i was asking is because i already knew that the sticker in my jamb would be incorrect, but someone on here who owns a GT which came with these wheels woudl have a matching sticker. I dont mean to come off as an @$$ but you answered my question assuming my ignorance.
ORIGINAL: backinblack06
Proper tire pressure per the automaker is listed on your driver door. You need to use the tire pressure listed there, not the pressure listed on the tire. You will get a much better ride and wear pattern if you fill them up to factory spec.
ORIGINAL: fairlane292
Proper tire pressure is indicated on every tire. Am I missing something with this question?
i have the GT Take-off rims from saleen, but i don't know the correct tire pressure for those tires. Anyone?
they look like this http://www.mrx-enterprise.com/MUSTANG.jpg
BTW....your title to this thread is "STOCK PERELLI TIRE PRESSURE" soo hmmmm.....yea keyword STOCK.... > get my thinking.
ORIGINAL: LesteR723
The Pony edition comes stock with the same wheel/tire as the GT -- so I have the 17" Pirelli with that rim. My car door sticker says 32/32 for that combination.
ORIGINAL: LesteR723
I have the same wheels .. 32 PSI...front and rear
R
They all say 32 front and rear. Saleen Im not sure about, but would bet it should technically be different.
When straying away from stock size tires the load capacity of the tire changes, and this is what you want to keep as close to stock as possible. A different size may require more psi to handle the factory tires load capacity. Or vice versa.
Did I lose anyone there?
ORIGINAL: JimC
LesteR
ORIGINAL: LesteR723
ORIGINAL: LesteR723
i realize that, but look at my sig
ORIGINAL: JimC
LesteR
ORIGINAL: LesteR723
ORIGINAL: JimC
Looks like the same wheel and tire combination as mine on your 05 on the left and that you stated in your post (Saleen take off is the wheel/tire combination from the GT -- unless I mis read your post, you have this tire and wheel and not the Saleen wheel) -- mine is the 4.0 V6 as well, and came stock with the wheel and tire you were asking about -- as you can see in my sig. Maybe I missed something in the thread and your sig?
ORIGINAL: LesteR723
ORIGINAL: JimC
LesteR
ORIGINAL: LesteR723
09-01-2015 08:16 PM
