Which fuse do I tap for the remote wire amp connection?
I'm hooking up an amp to the shaker 500. Do I tap the fuse under the dash(number 20 labeled Radio - Start) or the one in the engine bay labeled radio for the remote on wire?
RE: Which fuse do I tap for the remote wire amp connection?
ORIGINAL: blk05stang
Ive done dozens of installs and never fused it before
ORIGINAL: doode
um....why do you need to fuse a remote wire?
ORIGINAL: drbobvs
Neither. It's easier to tap into one of the unused spots in the passenger side footwell.
Go to Autozone or any auto parts store and buy a fuse tap. This device will retain your factory fuse and give you another fuse for amp.
I used one of these when I installed the PIE adapter for my satelite radio. It makes the installation very clean w/o splicing into existing wires.
ORIGINAL: Slink
I used the fuse for the power mirros since they always have power. The PIE instructons stated to use a constant power source. If this is for an stereo amp, I would the power window fuse or radio fuse since these items require the key to be used.
