SCT X-Cal 2 question
I just got the X-Cal 2 and it says to remove the fuel pump and electric fan fuses. However, I have absolutely no idea which fuses to remove, as the owner's guide doesn't specify. Does anyone know which fuses I have to remove?????
RE: SCT X-Cal 2 question
I have flashed a few times and never bothered to pull fuses. Just make sure the battery is fully charged before you start ( in other words if your car has been sitting idle for an extended period of time take it out for a ride or charge it with a charger).
The concern is if your battery should drain too low during the 10 min initial load (it copies your factory tune into the Xcal) You would be stuck having the dealer reflash your car, and this would not be covered by your warranty ( unless you could convince the dealer that it died due to natural causes). |
Nevermind. I figured it out. All I had to do was turn the page. IDIOT!!!![:@]
