Tire Warrenty Question
Well i had to add air to the driver's rear tire about a week and a half ago. Went out to lunch yesterday and noticed it was running pretty low again. I could easily push the rubber in with a finger. Question is, what does the tire warenty cover? I searched the tire and found no physical objects or anything stuck in the tire. Could i get this replaced under warranty? looks like a slow leek
RE: Tire Warrenty Question
Need to find the leak (could be valve stem); take tire off; use dishwashing liquid and little water; spread over area and watch for any bubbles that "grow" as air leak expands them. ...quite easy to find leak anywhere. Visual check tread first, if you see no issue work with the suds; test valve stem first, then outer and inner bead, then tread, then everything else. You'll find it.
09-08-2015 11:50 AM
