Amp Power Wire Placement
Has anyone run an amp power wire from the trunk of an '06 mustang to the battery? Im trying to figure out if there is a way using an existing hole in the firewall without having to drill a new hole. Any suggestions/pictures would be greatly appreciated
RE: Amp Power Wire Placement
If you remove the front right wheel and then remove the plastic cover piece in the wheel well you will see a big bundle of cables running into the car interior through a 4-5 inch rubber grommet. There is a little rubber nipple looking thing sticking out of the grommet. Cut it off and it is a perfect fit to run a 4gauge power cable through. You can then run it through to the engine bay through a hole near the top of the wheel well.
Thanks a bunch for the advice. I ordered the amp kit tonight and when it comes in Ill give it a go at installation! I am using the line out adapter from schose for factory radios with out pre amp outs. I want to keep the factory look until I get enough money for an aftermarket head unit. Any idea if this unit is any good?
Amp KIT? Ooooh be careful. Some of those kits really stiff ya. They'll claim 8guage cable but only be a 10g in reality. Take some calipers to those and make sure they didn't rip you off.
Unless you have enough juice to need 1/0 cable. Kinda hard to mistake that for 10g
i ran my wires through a gromet that is on the passenger side below the battery. nothing is running through it now but its there and its oval shape and it comes through to the upper portion of the carpet. good location ill take a pic for you tomorow.
I know this is an old post, but I am tryin to install an amp now and was hoping to use that oval opening too but I cannot tell where the wire should be coming out inside the car. Do you have a pic ANBAUTO that would help me out?? Thanks in advance!
jaiidutch
09-14-2015 10:29 AM
