Any 1 know where the SPEED SENSOR wire is so my Pioneer H/U can be installed correctly??
RE: Any 1 know where the SPEED SENSOR wire is so my Pioneer H/U can be installed correctly??
ORIGINAL: hawgman
Your new stereo shop is blowing smoke up your ***.
You need to pop the cap on the top PCM plug and look for a wire that is dark blue with yellow tracer.... there you have it myfriend. THATS youre output shaft sensor. No longer VSS because the PCM reads the OSS and makes up its own VSS inside of the PCM, so its electronic. You can read it with a scan tool and bring up the VSS pid. But you cant actually tap into it for your GPS sensor wire and it will work fine. I have had my Kenwood navigation unit hooked up there for over a year with no issues. Have also passed the info to people with Pioneers, Eclipse, and Clarion. All have worked.
[IMG]local://upfiles/13513/50C99612FB394E608009F2513F4D1154.jpg[/IMG]
Go to www.avic411.com lots of helpfull information there.
ORIGINAL: ThumperMX113
So you just tap into that wire?
ORIGINAL: hawgman
ORIGINAL: mAnYsTyLeS
My new stereo shop is saying that I need a $200 piece in order for my Pioneer AVIC-D2 speed sensor to work. Has anyone tapped into their Vehicle Speed Sensor and would you be able to tell me where it is on a 2007 Mustang GT (Auto)???? Thanks!
ORIGINAL: dmhines
You need a New New Stereo shop if they can't figure that out ... what may I ask are they doing for an illumination wire hookup?
