Sponsored by:
Sponsored by:
TPMS - has anyone tried this???
Old 01-08-2007, 08:22 PM
gt7er
gt7er's Avatar
Default RE: TPMS - has anyone tried this???
wow that's pretty sweet, howd you build the thing? did you get the pvc tube at home depot? howd you seal it? what about the valve stem? thanks
gt7er is offline
Old 01-08-2007, 08:50 PM
blueherd02gt
blueherd02gt's Avatar
I am sure you can turn this light off with an sct tuner....
blueherd02gt is offline
Old 01-08-2007, 09:23 PM
vsop
vsop's Avatar
I know the HRE rims I'm looking at has the option to get the rims with factory TPMS sensors installed.. But for $1300 a rim they better offer it as an option. I think its liek $250 or something for the set
vsop is offline
Old 01-09-2007, 01:41 AM
bcolem10
bcolem10's Avatar
Two inch pvc tubing from Home Depot with glue and end caps.Get a valve stem from your local tire store that is threaded. Drill a hole in one of the end caps install valve. Make sure one of the end caps hastwo inch pipe threads on one side so can remove the cap to install sensors.You can use smaller tube if you want. Set pressure at 32psi , check for leaks in some water. You should be good to go.
bcolem10 is offline
Old 01-09-2007, 02:04 AM
vsop
vsop's Avatar
If you go the PVC Route make sure you get one rated for 60psi to be safe (The really thin PVC is probably not a good idea). And use the PVC pipe glue (be sure to use it outside as its very strong)so one of the end caps don't shoot off. Since you will probably over fill it a few times and at 50psi it would pop pretty good if not secured.
vsop is offline
Old 01-09-2007, 02:37 AM
bcolem10
bcolem10's Avatar
Heavy wall pvc is rated at over 200psi. I have had it over 60psi for testing and no problems.There are two types of pvc glue, use the heavy duty type.Besure to use pvc cleaner first.
bcolem10 is offline
Old 01-09-2007, 08:36 PM
bcolem10
bcolem10's Avatar
Why do you want to spend money on inserting the sensors in the spare tire???? The PVC tubing is cheap, fast and small!!!! This is the best way to do it and it works!!!!!!!!!!!!!!!!!!!!!!!!!!
bcolem10 is offline
Old 01-10-2007, 07:29 PM
07GT
07GT's Avatar
ORIGINAL: bcolem10
Do you use teflon tape on the pipe threads? I would think it would leak otherwise. Why not just glue both caps on after inserting the sensors? If you had to take it apart you could always just cut it. If the threaded end seals ok that's the way to do it though. Thanks for the idea.
07GT is offline
Old 01-10-2007, 07:37 PM
vsop
vsop's Avatar
you don't thread PVC pipe even the threaded end cap requires you to glue on a injection moldedadpater.
You can use teflon tape, I find the paste to work better.
vsop is offline
Old 01-10-2007, 08:25 PM
GrabberOrange07
GrabberOrange07's Avatar
How long did you make your pipe?? This will give me something to do while I still wait for my car to show up.
GrabberOrange07 is offline
Quick Reply: TPMS - has anyone tried this???
