NON adjustable lcas... plug n play?
so if you install a NON adjustable lower control arm, say BMRs rod/poly combo, or just poly/poly combo, would you need to adjust pinion angle still? or is it just a slap em in and go? didnt know if you would need an adjustable upper to counter the install, or if the aftermarket does a good enough job measuring the damn pieces so the pinion and driveshaft angles dont move.
RE: NON adjustable lcas... plug n play?
I did the BMR non-adjustable LCAs and relocation brackets. I did not measure things, but I would assume that the increased distance to reach to the bracket induced some pinion angle changes (for the worse). I have not heard any noise. I also have not noticed any improvement in traction with my useless 235 P-zeros. But that is a tire issue.
Daddys Girls GTs
09-14-2015 08:46 PM
