Camber Adjustment Bolt Installation
RE: Camber Adjustment Bolt Installation
I also have the camber bolts and noticed the 77 lb-ft torque spec. This worries me a little since the stock bolts are spec'd at 148 lb ft. Given that these two bolts are the only things holding the wheel on, I am a little hesitant putting on a bolt at half that torque. I'm getting the car aligned today and I don't have the bolts installed, will see what they have to say about the torque difference.
I was also worried a bit at first about the Camber Bolts as they are thinner than stock bolts. But, then I looked the
Camber Bolts and at the top of the bolt there is a mark 10.9, that means that the bolt is made of stronger steel than
the original that is probably classified as 8.8 bolt i.e. weaker bolt.
And thanks moosestang, I was also thinking that what the heck is the washer that came with the bolts
[/align]
Correction to bolt classification, I checked the stock bolts and they seem to be 10.9 also.
[/align]
[/align]
[/align]
09-01-2015 08:16 PM
