Finished my linelocks finally........
I think the hardest part was figureing out where to place everything. I knew I wanted the solenoids mounted in the engine compartment. I originally decided to mount them both on the drivers side strut tower and run the stock lines from the abs to the solenoids and then bend new lines from the solenoids back to the abs, but it looked like there were two different sized fittings on the 4 lines coming out of the abs so that canceled that idea. Instead I mounted one on each strut tower and bend the stock line going to the passenger side brake back under the frame up to the solenoid, then ran a new line from the solenoid back to the brake. I was a little worried the stock line wouldn't reach so I mounted the solenoid as far down on the strut tower as possible. That made tightening the lines a little more difficult since the fuse box is right there. On the drivers side I disconnected the smaller fitting for the drivers side front brake from the abs module and bent the line over to the solenoid then bent a new line from the solenoid back to the abs, very easy, but bending the stock line isn't very pretty. Anyway i did the passenger side first and tested it on the road for a few days before going after the drivers side. I just wanted to make sure nothing would leak. Tightening the fittings securely is key to no leaks!
Anyway as they say[sm=ttiwwp.gif]
so here they are
first the new fitting/line going to the abs module, notice the two center fittings look smaller than the outer fittings, still not sure why this is. I put smiley faces on the fittings with larger ports.
futher away shot of the abs
Drivers side solenoid, notice my funky looking bends in the stock line, i didn't want to try and bend it too much since it was allready bent once.
passenger side solenoid.
cheap rocker switch from discount auto
so here they are
RE: Finished my linelocks finally........
Looks good, but why did you need two? Is that the kit made for the 05+? On my old 2004 some people said you need 2. But the SLP kit was just 1 solenoid and it worked just fine. I am thinkin of getting the 05+ SLP kit for my 06. Is 2 solenoids required?
Well the single solenoid kit if it mounts between the abs and brakes must have more than two ports and if so you'd loose individual abs control to each front wheel, when the solenoid is de-energized the front brakes will share fluid. If it mounts between the master cylinder and abs i've heard it will cause an error because the abs can see the brakes are locked, but i'm not sure. I ordered two solenoids from summit racing, no kit. I ordered there installation kit, but it was basically worthless so I ended up using the longest line from the summit installation kit for the drivers side and buying a longer line from napa for the passenger side. I also used two adapters from the summit kit (it came with plenty that were useless) and had to buy two more of the same adapters from napa (which were very, very cheap by the way). The brake line from napa was $5 and came with flared ends and fittings. I might redo it with some black painted line later.
ORIGINAL: redfireshaker06
Sorry, my digital cameras don't do videos. I've been meaning to get a cheap one that does though.
ORIGINAL: redfiregt2006
This thread is worthless without videos LOL!!
Excellent documentation. This is great info for anyone wanting to install a linelock. Now I have to say this, teflon tape is not a good idea for brake line fittings. It is not needed and can get into the brake system. I have seen brake system problems where very small pieces of teflon tape were flushed out of the system. If it were me I would redo it immediately without the teflon tape. I am just trying to help so please don't take this as offensive.
+1
With flared fittings the flare seals the connection and not the threads. Brake lines also use DOUBLE flair. Never use compression fittings.
moosestang, is the rocker an arming switch? If so where is your activation switch?
ORIGINAL: 07GT
