Went to track today! timeslips inside!
RE: Went to track today! timeslips inside!
ORIGINAL: moosestang
Yes, because the manual has more hp at the wheels.
ORIGINAL: bl1nkage
Would the stick trap at higher speeds than the auto because mine seem to be significantly lower than yalls.... I get a pretty consistant 102...
ORIGINAL: doodad
well, i haven't driven tuned new stang so you might be right.. try it.. it won't hurt you.. i tired and i saw it didnt work and i didnt try again..
I shift around 6300. I believe my rev limiter is set to 6800.
ORIGINAL: 07GT
What rpm are you guys shifting at?
ORIGINAL: doodad
Not all cars are equal and I wouldn't assume I have only 10 extra horses over you even if our mods were identical. Does your car shift to 4th in the 1/4?
ORIGINAL: bl1nkage
Well Im modded and I didnt figure the 10 hp difference would be much of a difference to trap speed, I was figuring it had more to do with the gears?
ORIGINAL: bl1nkage
ORIGINAL: bl1nkage
ORIGINAL: bl1nkage
ORIGINAL: doodad
at which rpm your car change gears?
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
