Proud to Announce: 13.43@102mph BONE STOCK!
RE: Proud to Announce: 13.43@102mph BONE STOCK!
i launch around 3K RPM.. but i kinda launch different than many people and works perfect for me.. i dump the clutch (actually slip just a little) and NEVER floor the gas pedal at tree.. i just hit the gas maybe halfway and then floor it ( i do this about less than a second.. very fast). do a decent burnout on dry pavement.. that will help a lot! and dont forget to lower your tire pressure to 20psi.
I noticed u have aftermarket rims.... do u also have drag radials?
Either way, ur trap speeds are kinda low for those times, which means ur launchinglike a rocket and hitting all of ur shifts perfectly. nice [sm=smiley20.gif]
ORIGINAL: SpecterGT260
ORIGINAL: doodad
my wheels are not aftermarket.. they are 18' aliminum polishhed wheels from the factory.. they were option.. i do not have DRs and i have to say my stock tires are pretty bald.. i can take pic and post here.. i have done TON of burnouts with them..
ORIGINAL: KTownGT
you are runnning 13.4 on bald tires? please enlighten us as to how you can run that fast Mr. Evan Smith [8D]
ORIGINAL: doodad
if you guys can remember, i was looking for DRs so bad and i even posted here if i could borrow somebody's DRs my tires are bald.. NOT smooth bald but i tested with discount tire's tire tester and it was showing ' COUTION.. REPLACE THE TIRE' now you imagine
thats pretty impressive.
I still think its awesome how low ur traps are for those times. hell, PI GTs usually trap higher than 94 (from ur sig) and run at least a half second slower. I think 14.0 @ 99 is about normal..... my mind is boggling.....
I really need to put my car on a dyno. I just got walked by a LS1 T/A. I was alright up to mid 2nd gear-3rd gear then it was bye-bye.I def could have driven better though. I don't think it was stock though. I've run better against them in the past.
[sm=jawdrop.gif] NICE!
you could fare against a LS2 gto!
EDIT: the best of motortrends test drivers could only get a 13.3 out of the ls2 gto http://www.motortrend.com/roadtests/...ecs_price.html
NO regrets over gettingmy stang
