Sponsored by:
Sponsored by:
BOSS 302 CYLINDER BLOCK
Old 11-10-2006, 02:31 PM
cnapsys
cnapsys's Avatar
Default BOSS 302 CYLINDER BLOCK
Just noticed that it is featured on the home page of frpp website. Coming early 2007
Would this fit just fine in our GTs???
I think the price is not bad at all. I would consider swapping it if I can get more details about what is involved parts and labor wise!
cnapsys is offline
Old 11-10-2006, 02:37 PM
bascho
bascho's Avatar
Default RE: BOSS 302 CYLINDER BLOCK
If your GT is a 1994 or older it should fit just fine. It will definitely fit in the modular engine bay as the small block (Windsor) is very narrow compared to the modular (Romeo). This will require significant modification to the engine mounts as the Windsor small blocks and the Romeo modulars are completely different animals.
Not to mention you will have to get all the parts needed to complete this engine as none of the exhaust or induction will transfer to the Windsor block.
bascho is offline
Old 11-10-2006, 02:46 PM
bl1nk
bl1nk's Avatar
Would it actually bolt flush to the stock transmission or would you have to go aftermarket tranny as well? Just something else to consider... an aftermarket tranny could run you like 4k
bl1nk is offline
Old 11-10-2006, 03:53 PM
CrazyAl
CrazyAl's Avatar
There is a LOT of difference between this block and the 4.6 block.
The Boss 302 is a pushrod style engine. Literally every part is going to be different than the new modular engines. Heads, intake, Motor mounts, exhaust, transmission, starter, accessories...everything will have to be custom.
CrazyAl is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Dathan
10-05-2015 05:52 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
69Volunteer
09-30-2015 10:39 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: BOSS 302 CYLINDER BLOCK
