question to manual tranny owners!
when you drive your car on to a bumpy road, does your tranny shakes?? mine does, i can see it and feel it like my WHOLE tranny shakes, i feel it when i put my hand on my shifter and i see ity when i look at the shifter..it shakes!! i am not sure but i didnt have this before, lately i feel it.. i will take it to dealer.. i think something is loose down there or bad tranny mount!
RE: question to manual tranny owners!
ORIGINAL: doodad
If I push in the clutch and don't shift while going down my washboard dirt road I hear a clunking. It sounds like it's coming from the rear, but I know that can't be. Something must be shaking at the tranny.
On second thought it more of a loud rattle, like the noise my adj. LCA's were making when the jam nuts worked loose. They don't come loose now though.
ORIGINAL: moosestang
whenevr i drive my car, my right hand is on my shifter most of the time and damn shifter is shaking VERY noticable!! today i just watched it and it was shaking pretty good..
ORIGINAL: doodad
I have the washboard road, not doodad. I can feel my shifter shaking on any road, but I don't feel it's excessive. I also have the hurst shifter which will shake more than stock because of the bushings.
ORIGINAL: 07GT
On a washboard road I would expect that to be normal. When you get on and off it do you feel movement? That would be more of a sign of a possible problem than lots of movement on washboard/bumpy roads.
ORIGINAL: doodad
The shifter does shake. How much is the shifter moving 1/2 inch?, 1 inch? 1.5 inch? You get the picture. Without driving the car, feeling the shifter, and knowing how bumpy the road is, it's hard to say. I can say that Ford has made all the motor and trans mounts to isolate NHV. That is why you will see more movement in your shifter. The motormounts are hydro and I haven't looked at the trans mounts, but I'll bet they're soft. For Doodad, again, check underneath, it's probably normal, but check!
ORIGINAL: doodad
Must have been those 7 or soo runs you made down the strip this past weekend
I think its normal
