warranty work done! NO PROBLEMS
Dropped the car off thursday night and picked it up at 2 on saturday. They fixed my dash rattle, auto shifter bezel/boot vibration, and changed out the clutch packs per tsb. We will see how well they did. After initially being pissed at the service reps for treating my girl bad, I am extremely happy with the service techs. He road with me for like a half hour till i could duplicate the rattle, and he took my word on the shifter. Because of course the car didn't make the noises like it usually does. Hope you all have the same luck.
RE: warranty work done! NO PROBLEMS
ORIGINAL: TPony
Whenever you can...asked them how they fixed the dash rattle...that one intrigues me...
Congrats!
I am getting a rattle between the A-pillar & the dash. Tried shoving a thick rubber gasket down there but it just slipped through!
I guess it means taking the car back, again!
Did anything happen to cause any of your rattles? Mine started after the body shop painted the entire rear quarter panel, which runs all the way up over the door and down the A-pillar. So they removed the inside plastic lining and I guess they had a 16 year old illegal alien put it back together! When I went to pick it up I had to point out that the area in the rear under the window wasn't even attached! And then the rattle started. Also I just found out that they screwed up my driver's side rear coat hanger too! It won't hold a jacket and just spins around. Did the idiots leave off a nut from the other side?
Hate to one up you, but
The dealership called me the other day. They had my car for the Fuel pump TSB, leaking Valve cover, and the leaking Brake Resorvoir Cap. They called me and asked if they could have the car for a couple of weeks because they were going to have to remove the master cylinder,etc. I said No problem. Fair Oaks, Napierville, IL has to be the best dealership I have ever dealt with period. I even grew up in dealerships, my dad was a Master Tech, and have never been treated this good.
