4.10's go in Saturday..oil question
#22
RE: Beating the old oil question
Also. i believe if you change your rear diff cover to a aftermarket, it wont clear the panhard brace, i remember reading a article that BMR has a panhard relocation bracket that moves it out about a Inch, so it clears...
Might want to double check on that....
#24
ORIGINAL: Ford_Dude
the only thing conventional oil is ggod for is seating the Piston rings
for the diff it should be fine to go strait to High Performance Full Synthetic oil
The point wasn't that the Redline would be bad or hurt anything. The point is why spend the money when it will be drained in 500 miles. that to me is a waste and not needed during break in.
Richard
#27
ORIGINAL: torch red
Att. Andrew
#28
ORIGINAL: androdz
Why would you want to change the diff cover?
Att. Andrew
ORIGINAL: torch red
Att. Andrew
#29
ORIGINAL: Ford_Dude
I think he would want to change the cover for one with a drain plug for easier fluid change
ORIGINAL: androdz
Att. Andrew
ORIGINAL: torch red
Att. Andrew
Att. Andrew
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
junior04
09-28-2015 10:53 AM
