need help with stock rasio removal
RE: need help with stock rasio removal
Remove the two screws at the rear of the console under the door.
Remove the shifter trim (for the auto, don't know if it's the same for the manual)
Gently lift the center console cover off and manuever it over the shifter. Remove the two wing trim pieces either side of the radio - they pull straight out.
Remove the six screws holding the Instrument Center Console then remove the plugs from the back. Be careful of the vent selector switch plug, lift up the blue locking tab holding the plug, then pull the plug.
Remove the four screws holding the radio.
See the diagrams here:
Service Manual PDFs
Service Manual PDFs
M3hunter
09-05-2015 03:42 PM
