Bass button on shaker 500
Long story made short, my radio is mounted behind the dash and I can't read the letters on the "screen" portion of the shaker 2005 headunit. However I can access the buttons. I want to turn up the bass, can someone please tell me the sequence of what buttons to press to turn the bass up? For Example"press menu three times, and press/hold the up arrows on the right side of the headunit."
Thanks
Thanks
RE: Bass button on shaker 500
the shaker 500. depends on what mode you are in. if you are listening to the radio, i think you have to push the menu button 4 times then using the seek buttons, adjust the bass right for more and left for less.
if you are listening to a CD, push the menu button 3 times then use the seek buttons as described above.
i am certain you have to push the menu button 3 times when listening to a CD. just not sure if it is 3 or 4 when listening to the radio.
ORIGINAL: Brent05Redfire
hmmm....
ORIGINAL: Black06stang
Thanks
Thanks
Im not sure what you mean by its mounted behind the dash...but +1 to turning up the interior lights
ORIGINAL: Fambaa
Thanks
Thanks
So, does anyone know what sequence to use to raise the bass while in auxiliary mode? (the bass may or may not be all the way up...I just want to be sure).
Ill post some pics tomorow of the install, the screen etc.
