On the way..Saleen Supercharger!!!!
Well, I did it this time...I couldn't wait any longer I made an offer on ebay for a Saleen aupercharger base kit for $4500 and the seller accepted it, including free shipping. Now for those of you out there with know how...I have a C&L intake, can I use it with the blower?? how about the motor mounts, I saw on a forum that if you stay with the stock 4.00inch pulley that I did not need to lower the engine....anyone with info, I would be glad to hear....Thx
RE: On the way..Saleen Supercharger!!!!
I just got mine from Hillbank but am waiting on the upgrade kit due to Saleen trying to keep up with the demand. I put my JBA shorty headers on awhile back and changed out my mounts at that time to the solid ones. I also have the C&L inatke but will not use it when everything is installed. I have read the manual and nothing is mentioned about changing mounts using a stock hood. My installer who I have talked with about also did not mention needing a mount change though JBA recommended using solid type versus the factory fluid ones. I intend on using my original air intake but adding the upgrades that Saleen has in their kit.
the upgrade kit brings HP from 435 to 475 and includes, 39# injectors, 3.8" pulley, airbox lid, and air plentum. instuction manual
I just sold my unused one!
05SDI
05SDI
ORIGINAL: FiremansGT
Are you going to use the Saleen tune? BTW, it runs lean and that's not good for your motor no matter what they say. Find a good tuner to set up your tune. DON'T just go to anyone, ask around a lot. I drive 120 miles one way to see my tuner (St Motorsports).
If your going to use a tune other than Saleen's, you WILL need #39 injectors, 90mm MAF. If you don't get them your motor won't run correctly.
Thx for the reply...I was planning on contacting JDM Engineering about a tune, what size injectors come with kit??
Best deal I've seen.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
