Web Electric Sequencial Turn signals
RE: Web Electric Sequencial Turn signals
I agree with the do it yourself kit. Way cheaper and takes about an hour start to finish. I also agree with soldering the wires. I have them on both of our 06's and waited almost a year between getting and installing the two kits. (and the price didn't change) Same quality and I really like how it makes the inside most light on each side come on when ever you use your blinkers and brakes. (you don't even have to change the light bulb) Instructions are very good!
Edit to clearify; We bought one kit & intalled it last year, and then last month we bought a second kit through this same company and installed that one two. (didn't eat the mints though lol!)
Sequencial tail lights
Well i know of one guy who was running the CDC kit and it caught his car on fire. Screw those self wiring kits.
The WebElectric guys i the original. Plug and Play and took all of 5 minutes to install. By eh way the Sequential Brake happen so fast that you really have to even look to notice it. At least in my opinion. I love the way they work.
The small amount of extra money was well worht it in my opinion. And you can get like 30 or 40 back if you send Web your stock harness back so they then are right in line price wise with the others.
Richard
Richard
ORIGINAL: Riven02
What makes this better than the CDC kit? I ask because the CDC kit is cheaper.
Location: Raised in Chicago; living near St. Louis in Troy, IL
I have their "plug-n-play" kit (as someone else called it) and I love it. Easy to install, brakes stay normal, and not one problem since installation....and the company gives top notch service!! Definitely worth the $$.
I just finished installing the unit from Meter4it.com.
I was worried that I would screw things up so I contacted Gary at Meter4it.com and he gave me some tips and additional info to insure I got it right. Take about tech support. The kit was $129 with shipping and showed up at my door in a week.
For those that are afraid to cut into their original equipment wiring, get a pair. Once the rear trim panel it in place, who will ever see it. Not that there is a lot of cutting required. Two wires on each side. You would have to cut with any splice kit.
The install took me about two hours if that. Less if you have to tools ready and it's more then 20 degress outside.
The unit works in factory, chaser and sequential mode. This is better then the other units I have see online which only have one option.
For those that are lookign for a until check this one out.
www.meter4it.com
http://www.meter4it.com/Video/2005_M...tang_Video.wmv
www.meter4it.com
ORIGINAL: 1BADD05
I HAVE AN 05 AND GOT THE PLUG AND PLAY FOR IT FROM CDC, AND YES IT WAS 20-30 CHEAPER THAN WEB. AND I LOVE IT! INSTALL ABOUT 10 MINUTES!
