camber bolts needed???
Hi All,
I'm getting ready to install Tokico D-spec struts & shock with BMR 1.5/1.75 lowering springs along with BMR adj. lca,panhard rod. I ordered camber bolts thinking that I will need them for the camber correction after install. Can anyone chime in with their lowering mods done with answers if the bolts are needed or not and was it enough to bring camber back into specs. Thanks
RE: camber bolts needed???
You will most likely need camber bolts. After I got my car aligned I only needed one but I imagine you will need both after that kinda drop. Make sure to take you car in for an alignment as well.
91StangOwner
08-20-2015 11:34 PM
