Limited Slip Differential - Good or bad for Mustangs in the snow?
As the title says. This weekend on Powerblock TV on Trucks Stacey what's his name said LSD's are bad for snowy weather as both wheels spin vs. one wheel spinning meaning worse traction. Yeah I know it's better on dry pavement and in the mud, etc., but for snowy roads, is the LSD worse or better? I'm thinking worse since if you spin one wheel, you spin em both, and it's far easier to lose traction with a LSD in the snow vs. without...
RE: Limited Slip Differential - Good or bad for Mustangs in the snow?
IMO LSD's are better to have than not in the snow. Yes if both wheels spin you can lose centripital traction, meaning you may go sideways. However, one wheel drive (essentially no lsd) usually cannot move a vehicle in any significant amt of snow from a standstill. So yes, for getting going, two wheel drive is better than one by far, but it could cause you to fishtail. My advice is just common sense, in the snow, easy on the throttle, keep TCS on and don't gun it in the curves.
Well i drove my stang in the snow for about 9 mins.
During that 9 mins i got a total of 9 feet.
There was maybe about 3-4 inches of snow on the ground, and it plain sucked,
Funny enough, my volvo with an open diff is no better.
Call me lucky or whatever you want but when I was 16 I had no issues getting my dads 8000lb open diff 1981 Buick Lesabre through the snow. Last year I drove home to St. Louis from BFE NM through a little snow. No issues. Just drive responsibly remember your driving a 300hp rwd car through the snow and you shouldn't end up like the yuppies in their AWD/4WD SUVS stuck on the side of the road. But the best solution is not to drive your stang in the snow.
ORIGINAL: doode
so far, so good...it's 65 degrees today :-D
ORIGINAL: imyy4u
This is what I'm worried about. My GT is my daily driver and my only car. Can't afford a winter beater. Also have nowhere to park it. And to make it worse, I depend on my car for my job...I drive 100 miles+ daily...I got 2 snow tires for the rear but I'm still scared about being stuck in this Chicago winter...
ORIGINAL: doode
ORIGINAL: imyy4u
Driving smoothly is the key to safe winter driving. But after having said that, I would still be worried about the other idiots on the road.
As far as LSD goes, "Limited Slip" means just that. 2 wheels gripping is better than 1 wheel trying to get a grip.
ORIGINAL: wingman75
Before front wheel drive we all drove rear wheel drive cars and survived (most of us did anyway). Just start off in second gear, and go easy on the throttle, then shift smoothly keeping the revs steady, don't let them fall off or suddenly rise.
ORIGINAL: imyy4u
Diode Dynamics
28
05-26-2022 12:02 PM
