Audio Deadening & Removing Seats?
RE: Audio Deadening & Removing Seats?
I used a combination of the sheets (Damplifier Pro) and the Spectrum liquid. It worked very well!
I hit the wide, flat areas with the sheets first. Then I sprayed everything with the liquid. I used aluminum foil to mask off the trunk air vents, electrical connectors, and other important bits. I masked the windows with painter's tape and wax paper, then sprayed it in good. Let the spray cover wires and such, that way it stops the wires from rattling against the bodywork.
Clearym, I got your Email, and I replied to it. But it seems you may not be getting my replies. Let me know if you recived the attachment I sent you.
jwog666
12-27-2021 08:09 PM
GT350 S550 Tech
09-29-2015 03:29 PM
