C+L air inake w/sct x cal 2
Ok here is my ? I am thinking about getting this for my 06 but I am not sure how hard it is to install I am sure that the intake will be no problem but I am not sure about the x cal2 how hard is it to install or should I buy the air intake and then find a local dealer to tune it. ( I want to make sure that it is right so I don't have any problems in the furture) Can a caveman install this or not any advice on this would be great. Also if u know of any dealer in the Indianapolis area that does this that would be great also Thanks in advance
RE: C+L air inake w/sct x cal 2
The tuner couldn't be easier. Just plug it into a socket underneath your steering wheel, follow the on screen prompts and you are done in a minute. Then unplug and put the tuner back in the box. Nothing to it.
Its so easy, I did mine right at the gas pump when I filled with 93 octane the first time. " A cave man CAN do it " Hell I did !
[IMG]local://upfiles/47655/15118E9EBCB54BAD9456EF4985607528.jpg[/IMG]
[IMG]local://upfiles/47655/41460A28B57E4FA38CCA9104EDFC7100.jpg[/IMG]
ORIGINAL: Mike65
I've lost my appetite.
[IMG]local://upfiles/21761/E7F82225551A45C19C4B2BE38DCDDEE1.jpg[/IMG]
ORIGINAL: Warlok
"Look's Like Someone Woke up on the Wrong Side of the Rock"
daltron
04-28-2016 08:10 PM
