exhaust installation
Installed the Ford Racing stingers. My left side is OK but the right is off and hitting the bumper. I noticed the stock exhaust has a nod on the exhaust and the new exhaust has a cut out in the pipe. I alligned these and played with the brackets but still cant seem to center it. It seems like the exhaust pipe was bent a little to far. I think Im going to have to go to a muffler shop and have them possibly bend it straight. Any recommendations on how I can align it? Also do the clamps install over this nod or do they install beside to it?
RE: exhaust installation
I own a couple of flows, installed them at a friends house, then took them to the shop to fine align them at the bridge. Had to loose a bolt an rotate a little the stock overaxle pipe to make them fit right. Lasted about two minutes there.
I installed with no problems like you are describing. No bending is required. I installed just like factory next to notch. Others have installed clamps over or on the other side of the notch.
It requires a lot of test fitting. I had to bend the hangers and install it 7 or 8 times while adjusting it until I got it perfect. Just be patient and you'll get it.
[align=left] [/align]
ORIGINAL: PROMETHEUS PRIME
loosen the clamp(with the two 15mm nuts) after the H-pipe and twist the back portion of it.You should'nt have to bend the hangers.
