How good is the Traction Control on the 05-07 Mustang?
RE: How good is the Traction Control on the 05-07 Mustang?
ORIGINAL: NewMustang
So, is the Traction Control unit on the GT same as those on V6?
Anyone Mustang V6 owner here that has TC equipped? How good is it? It gets quite a bit snow here, I'm not sure if I should drive it when it snows. Don't want to crash my new car.
Thanks.
Thanks.
I think it does exactly what it is designed to do however unless it's raining I drive with it off. It's great in the rain but in dry pavement it is in my opinion dangerous. I was going hard into a corner once and she got a little loose in the back which would have been fine except for the the fact that that traction control caught when I was in the middle of trying to compensate. Had the car just been allowed to spin I would have been fine but I just wasn't expecting it to suddenly grab and I almost lost it. From that point on I always drive with the TCS off unless it is raining.
Useless in the snow.
A great feature in the rain.
Always off in the dry.
In the rain, sometimes i forget just how much torque the motor puts out.
I've punched the gas in 3rd to pass a car a few times in the rain and if the traction control didnt step in, my rear end would step out a foot and i'd be sideways down the street.
I had mine shut off in the tune, much happier. If your not familar with rear wheel drive it probably won't compensate for your lack of knowledge.
My feeling is it works ok. The mustang is a rear wheel drive sports car so it isn't the greatest in the snow. I think the tc helped me a bit in the snow but you will slide out if you are not careful. I think I'm going to get snow tires for the winter. Would love to have a second car but that isn't going to happen so I will just probabl get snow tires. I have used the tc in te rain also and it does slide out if you are not careful. If you get a mustang be prepaired for the rai and snow and just don't drive like a moron in it and you will be fine.
when i turn my car on is the Traction ontroll on or off. i raced a pontiac GTO and i was bone stock and so was he. When the light turned green i just spun tires why did it do this...
It works, you'll get a little spin before it kicks in.
I have it off in my tune, i've never driven the car in snow or rain.
I've been much more impressed by traction systems in some BMWs and Audis I've driven. Leaps and bounds better, Ford did an alright job though.
what traction control?
i popped the clutch at a stop sign merging onto a highway and my wheels totally broke traction and i got sidewaysand i don't know that the traction control did anything at all!
i guess it's possible that had it not been on it could have been worse...
it's kicked on before going around corners but it usually seems like too little too late.
