Sponsored by:
Sponsored by:
silverstar bulbs question
Old 12-27-2006, 09:51 PM
skillful
skillful's Avatar
Default silverstar bulbs question
OK, I know there has been alot about the bulbs so here I go. Will the silverstar bulbs make the clip in the fog lights fall inside or not?? I bought the Xenon bulbs long time ago and the clip fell inside both lights. No bid deal just take it to the dealer and get them swapped out. I just want to avoid that issue with a new set lights.
skillful is offline
skillful
skillful's Avatar
Default RE: silverstar bulbs question
and how much do all 4 cost?
skillful is offline
Old 12-27-2006, 10:03 PM
Gman13
Gman13's Avatar
you just have to be careful installing them. If you don't hit the clips inside, you should be ok. I hit the clip installing a bulb and had to work with it for a while to get it fixed. PITA The bulb itself will not push the clip out.
Gman13 is offline
Old 12-27-2006, 10:05 PM
Gman13
Gman13's Avatar
And the bulbs are about $20 each....
Gman13 is offline
Old 12-27-2006, 10:07 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
When I did my 4 bulbs I made sure I took off the whole fog light assembly. It guaranteed no ****-up.
mAnYsTyLeS is offline
Old 12-27-2006, 10:34 PM
skillful
skillful's Avatar
Im talking about the heat issue with the bulbs melting the glue that holds the clips. Didnt have a issue with installing the bulbs. Thanks for the input.
skillful is offline
Old 12-27-2006, 10:42 PM
06GT4RAD
06GT4RAD's Avatar
The Silverstars do not run HOT like many of the aftermarket bulbs becasue theya re the stock wattage. Most of those other aftermarket bulbs draw 100watts.
Richard
06GT4RAD is offline
Old 12-27-2006, 10:43 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
If you get stock wattage you will have no problems with any bulbs. The only problem I've heard is when people actually knock those clips off because of not being careful.
Old 12-28-2006, 02:15 PM
SlappyGT
SlappyGT's Avatar
I managed to knock both of my clips out changing my bulbs to the Silverstars. I think part of the problem is that I had the Nokya bulbs in before the Silverstars, and they may have melted the glue a bit. So I pulled both fog light assemblies out, and between my dad and I, we got both clips back in place (probably better than when they came from the factory). Just be careful. The Silverstars themselves won't cause any problems, but you might...lol
SlappyGT is offline
lincolnshibuya
12-08-2015 04:37 PM
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: silverstar bulbs question
