Stock headlight wiring help
Guys,
I need to know which wire controls thelow beam and which wire controls the high beam and which wire is common. I assume the middle wire is common. Is the white for high beams?
RE: Stock headlight wiring help
Get a test light and someone to help you and then have them turn the lights on while you carefully probe the wires probe to locate the low beam then the high beam.
By the way what are you trying to do?
Richard
Richard
Thanks Richard. That's what I did. I got a neat little gift for Christmas called Flash2Pass. It's a garage door opener that activates by flashing your headlights 2 times. We only had 2 openers and one of them kept falling off the visor when my top is down so the wife got me this. It works great and only took a few minutes to install.
http://www.f2ptechnologies.com/
ORIGINAL: PROMETHEUS PRIME
So anyone can flash there lights to open the garage??? Cause if thats the case what was your address again.[sm=joke.gif]
Seriously though, there's a transmitter that is connected to the brights thus the reason for this thread. It works really well and it one less piece of junk hanging on my visor.
