Not impressed with tuner UPDATE!! LOOK
#31
RE: Not impressed with tuner UPDATE!! LOOK
Did ford replace the driveshaft under warranty?
Just curious?
Just curious?
ORIGINAL: grbrorng07
I told them what i had and what i wanted. I did get a responce back this morning that they do not up the shift responce because they do not feel the trans can handle it. I can accept that, but it would have been nice to tell me that when I asked up front. I can handle things better when I know what is going on. But to tell me OK when I order it then just not do it and keep it a secret bugs me. I have no hard feelings at them. I now have a tune that works great. I picked my car up today from ford. driveshaft replaced but much more damage. the e brake cable is broken and the Bottom floor is DESTROYED!!! Has two 3" long cuts and has separated the floor pan seams. Goes to the body shop next week. I am going to drive it some and see if any trans. leaks or other issues.
#32
The thing is, firmer shifts are actually easier on the tranny (to a point)... hmmmm...
#33
Sooo if Brenspeed doesn't make any adjustments to the trans, which supplier does? I was going to go with the Brenspeed tune because I want the firmness and timing changed in my auto.
Any good suggestions???
Thanks-
Thanks-
#35
ORIGINAL: BHRS
Thanks-
Thanks-
#36
ORIGINAL: vsop
Best V6 tuner is Justin at VMP Tuning (VMPTuning.com)
He started outfocusing onV6 Mustangs, and has done some amazing things with them.
#37
ORIGINAL: scrming
Cool.. now we get to start the great TUNER DEBATE!! It's almost as good as the V6 vs V8 debate! LOL!!
ORIGINAL: vsop
Sorry!!!!
#38
Did someone say Tuner Debate!!! I'm ready. LOL.
Ya, Johns right, I beat on my tranny too. Not sure how long it will last on my new setup, I'll let you know when I break it. LOL.
#39
Yes ford is replacing under warranty. new update, I just came in from the garage, from which i noticed my pasanger seat would not move. After fighting it, (I won) it is out. The tunnel has been hit so hard it has torn the center console from the tunnel and bent the seat bolt area against the tunnel. So now they get to order a new console. V6john is correct in that you can adjust the shift yourself. I am new at these tuners and believe me was scared to death of it. But it is easy to adjust and if you mess up it is easy to fix.
ernesto-619
09-10-2015 01:32 AM
