First Promblems with my GT point me to the right direction.
Ok... this is it, my car has 5k miles its a GT Manual transmission.
1. The car makes kind of a squealing noise when I make a slow U turn, seems to be coming from the diff.
2. The Steering squeaks when I move it, even with the car off you can hear the squeal.
3. At 40 to 60 mph I can hear the rear diff humming.
4. 1st and 2nd gear are noisy when they are engaged.
The car does have Mods:
- 20 Inch rims with 275/35 tires all around.
- 1 inch shorter springs in the rear.
Can this problems be fixed outside the dealer? because the only dealer I have near me is very famous for delivering cars worst than they arrived.
And do you think that the mods that I have done have contribuited to this problems. They are recent and did not happen when the mods were done.
Thanks in advance guys.
RE: First Promblems with my GT point me to the right direction.
I heard horror stories about people taking it to the dealer and having the car worse after the supossed fix, have you guys tried the XL-3 Friction Modifier?
Our engineer actually told us to set the packs looser to avoid this problem with the updated ones. I of course made mine tighter.
I did had Modifier to it but it didn't help.
I would tell you to bring it to my dealership.
Well I just added the XL-3 fluid... took the car to an empty parking lot to make some circles with the steering wheel turned all the way... and guess what?
It's gone I couldn't have the car make the noise, not even once.
Ill keep you guys posted in case the scenario changes.
I read on the many threads on this forum that a small amt of whine is fine. If not sure go to the dealer and have them do the TSB on the rear diff. I read that if you get a short throw shifter that will solve number 4!
jwog666
12-27-2021 08:09 PM
09-25-2015 09:06 AM
