Painted my valve covers
#21
RE: Painted my valve covers
Did you use LMRON paint..? Its the only thing I would use under the hood, as its a much stronger paint.
I would be concerned about the heat on the valve covers with the decals. I look foward to an update in a month or so. I just don't know how well the vinly will do over time being heated and cooled. It might melt or off gas under the clear coat.
#22
Looks good I always wanted to poder coat mine but after seeing the paint job it might be worth a weekend to get it done.
+1 on the write up great when someone remembers to take pictures along the way.
#25
Thanks for all the compliments guys.
I bought the paint at Autozone. It was the only gold valve cover paint they had.
After cleaning the valve covers, you should sand them lightly with a 220 grit paper to rough the finish slightly, this will help the primer adhere better. The gold paint had a lustre finish to it and after it dried felt a little rough. I sanded with a 1000 grit sand paper to smooth it out a little. Wetting the paper made it easier to sand. I used a can of engine primer, two cans of the gold paint and 1 can of the engine clearcoat. Each can was $5.99.
The decals are available directly from Ford racing, but you had to purchase them in very large qunatities. I did a search on Ebay and found them for $5 each. Here's the link:
http://cgi.ebay.com/ebaymotors/Ford-...mZ270060256556
#26
Thanks for the info and I now know where I will be after work tomorrow....:-)
The tuff part will be deciding on the color. I'm thinking the gold might look awesome on my black stang. I'm curious how the decal will hold up myself.
I wonder if this same paint will work on my C&L cold air intake tube?????
#28
I found a local place in FL that will do a polished finish Powder coat on my valve covers for $90 so I'm doing that. Its like $50 for a standard powdercoat. But I want the polished finish
#30
odiaz,
Do you remember what brand paint you used. I went to Dupli-color's website and they have 2 types of engine paint
1) Dupli-ColorĀ® Engine Enamel with Ceramic (good up to 500 degrees)
2) Dupli-ColorĀ® High Heat Paint with Ceramic (good up to 1200 degrees)
number 1 has about 36 color choices and resists oil and gas and number 2 only offers 6 colors but is resistant to a lot more things. I'm really interested in doing this but I want to make sure I do it right not to say you did it wrong. I'm guessing I could use just about any degreaser to clean then before primer right?
any input would be great
